I just got a evga sc 780 and when i put in on my mobo my pc dosent display an image and i know the card works because it displayed an image till i reset my pc and now nothing i updated bios set primary display to pcie all my pcie power plugs are fine the fans are on and i still cant seem to get it to post frames plzz help as i am stumped and i went back to my old 750ti and it reads it immediately
https://linustechtips.com/topic/641897-help/
Is it posting when you turn it on?
"There are 10 types of people in the world: those that understand binary and those that do not."
CPU:  4790K @ 4.7GHz  Motherboard:  ASUS Maximus VI Formula  RAM:  32GB Corsair Vengeance Pro 2400MHz  GPU:  (2) GTX 780 Poseidons in SLI  Case:  NZXT H440  Storage:  (2) Samsung 840 EVO 500GB SSDs and (1) 4TB WD Black HDD  PSU:  EVGA Supernova G2 850w  Cooling:  Custom loop - Koolance 380i CPU block, (built-in waterblocks on GPUs), Alphacool VP655 pump, (1) 360mm XSPC radiator, (1) 240mm XSPC radiator, Bitspower 150 reservoir
https://linustechtips.com/topic/641897-help/#findComment-8271492
first off how strong is the powersupply.
second, have you tried an other pcie slot?
have you tried other pcie power cables.
Can you get to the bios with the 780?
if not try to reset the bios( take out the cmos battery if needed and press power on button for like 20 times).
CPU:R7 5800X    Motherboard: asrock x470 taichi ultimate   RAM: 32GB G.Skill Ripjaws-V 2X16GB    GPU: Gigabyte GTX1080TI gaming oc 11g   Case: Corsair 600Q Storage: 1TB Samsung 870(boot), samsung 850evo 500GB, 2TB Corsair MX500, samsung 2TB 970 evo plus, WD 5TB black    PSU: Corsair AX860    CPU cooling: Corsair H105
https://linustechtips.com/topic/641897-help/#findComment-8271505
psu 500watt
mini itx
dont have any
no
will try
https://linustechtips.com/topic/641897-help/#findComment-8271601
the powersupply should be more than enough
shame you have no other pcie slots
if you have no pcie power cables send straight from the powersupply to the videocard it will not get enough power to give a post screen but the fans will still spin up, andunless i read it wrong you forgot to plug these into your card, and since the 750 doesn't need these i would not be supriced that this would be overlooked and that you dont see these
https://linustechtips.com/topic/641897-help/#findComment-8271647
im returning
psu 500watt
mini itx
dont have any
no
will try
https://linustechtips.com/topic/641897-help/#findComment-8271706
those were pullged in but im just gunna return the card cuzz i dont fell like dealing with this shit
https://linustechtips.com/topic/641897-help/#findComment-8271722
