Recommendations for a fan controller
If your fans are all 4 pin I would use something like this.
http://www.moddiy.com/products/PWM-1%2dTo%2d12-Fan-Splitter-Cable-(Sleeved).html
It takes the PWM signal from the MOBO (usually CPU_FAN header), uses the Tach signal from one of the fans, and draws power from the PSU. Because it draws power from the PSU, and the Fans always have a full 12V signal, your LEDs will not dim. Then just use the BIOS or Seedfan to control the speed. They will all be at the same speed, or at least rise and fall in relation to each other. I am currently using this system with two case fans.
Plugging a 3 wire fan into this harness will result in full speed and mucho noise, don't do it. When trying to control multiple fans, I don't believe there is a controller that will control both PWM and variable voltage fans.
