Hey Everyone! So I recently decided to build a super penny pincher PC. I already have the case, psu, storage, and gpu. all I need now is the motherboard, cpu, and ram. I have 150$ left in my budget for these parts. I am having a bit of a hard time figuring out what parts I buy. The build is for my cousin's birthday and he loves to play minecraft, and half-life 2. He wants a better computer than his parents old PC that he currently uses, which has a pentium d @ 2.6GHz, a GT 710, and 3gb of ram.
The only things I need in a list is an ITX motherboard, because the space he has for the PC isn't massive. It also needs to have 8gb of ram.  The GPU was scavenged from another system, so if the list has an APU in it rather than a CPU that's fine. Thanks for your time, and help!
https://linustechtips.com/topic/641396-150-for-cpu-mobo-ram-help/
You might need to purchase some used goods. Also what are the other things
What is the case, storage, PSU and GPU?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
2 minutes ago, ChipTech said:
The Case is a Cooler Master Elite 110
The PSU is a EVGA 430w
The GPU is a Asus Radeon HD 7450
well unfortunately you need to purchase some used goods. No other way around it unfortunately.
15 minutes ago, ChipTech said:
snip
Here you go
CPU: AMD A8-7600 3.1GHz Quad-Core Processor  ($69.99 @ Newegg)
Motherboard: ASRock FM2A78M-ITX+ Mini ITX FM2+ Motherboard  ($56.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($37.98 @ Newegg)
Total: $156.95
Generated by PCPartPicker 2016-08-10 20:28 EDT-0400
To bad you can't go Micro ATX. You could get a really good deal at micro center.
You can get a
For $89 and a
For $24
and buy some
Memory: Avexir Core Series 8GB (1 x 8GB) DDR3-1600 Memory  ($29.88 @ OutletPC)
Total: $29.88
Generated by PCPartPicker 2016-08-10 20:48 EDT-0400
And you would crush anything else at that price range. Its overclockable aswell.
My new Gaming PC.
Case: Coolmaster CM690III, Motherboard: Asus Z170-AR, CPU: I5 6600K 4.6Ghz, OS: Windows 10 HP 64 bit, RAM: X1 8GB G.Skill DDR4, GPU: Galax GTX 960 (Overclocked), Storage: Kingston V300 SSD 120GB(OS), X2 1TB 5400RPM HDD, 500GB Samsung 7200RPM HD, PSU: Cougar RS 750 Watt, Peripherals: Logitech G910 Orion Spark,  World Of Tanks Edition 2014 DeathAdder Razer Mouse And Mouse Pad, Sennheiser HD 518. , Palsonic tftv6042fHD, Logitech Z506 5.1 Surround Sound Speakers
