I've done my research...
Go to solution Solved by W-L,
16 minutes ago, Jack Dvorak said:
as I said in the title I now know how to assemble a full loop I just need recomendations on what parts. I will only  be cooling my cpu, so I don't need a GPU block. Radiator size won't be a problem as I'm building in the thermal take x9 with literally so much space. EDIT: Do I have to buy like pure water for my loop or what? Where would I get that stuff.
For a custom CPU only loop you could get a kit but for hardline you will need to individually select components, as for fluid you can use distilled water with a biocide or a premixed fluid which contains everything it requires. As for good options EKWB would be a good place to look.
https://linustechtips.com/topic/640886-ive-done-my-research/
Have you considered this?
https://www.ekwb.com/shop/ek-xlc-predator-360-incl-qdc
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/640886-ive-done-my-research/#findComment-8261462
I want a custom loop for looks, so no aios. I would like hard tubing
Do you want to bend the tubes or use fitting for the bends?
https://linustechtips.com/topic/640886-ive-done-my-research/#findComment-8261514
https://linustechtips.com/topic/640886-ive-done-my-research/#findComment-8261538
Other than using biocide a silver kill coil is also an option. you can reuse it in all future iterations of your loop(trust me the moment you are done with your loop you are already planning out version 2,0 in your head). Otherwise distilled water is still my favourite, you can do with it what you want and the recommendation to switch every half year or so stands for all kinds of fluids distilled water and premixed.
https://linustechtips.com/topic/640886-ive-done-my-research/#findComment-8262471
Just note of you have any nickel in your loop you shouldn't use silver as it's a borderline dissimilar metal in a loop environment, so using a compatible biocide like Petra's (clear) PT nuke or premix would be best in those situations.
https://linustechtips.com/topic/640886-ive-done-my-research/#findComment-8263033
oh yes most definitly, i'm just a all copper dude and havent had any corrosion problems yet. Easy to forget those two hate each other if you dont use nickel xD
https://linustechtips.com/topic/640886-ive-done-my-research/#findComment-8263095
