My case have 2 fans, one at the front and one at the bottom. And they both have a molex connector and a 4 pin. Should I connect both of the connectors or with 1 of them I am fine? Right now I have connected the back fan to Mobo (which only has one fan connector) and the other one only to molex (which is very noisy).
Thanks
https://linustechtips.com/topic/640002-case-fan-connectors/
2 minutes ago, Ichi said:
Connecting to molex simply means it will run at full speed all the time thus the noise.
If you only have 1 connector then get a splitter or a fan hub?
If that's not an option, I would go for 1 intake at the front to maintain that positive pressure.
Would this work?
https://www.amazon.com/Silverstone-Technology-Sleeved-Splitter-CPF02/dp/B00HJOJS9O/ref=sr_1_6?ie=UTF8&qid=1470667021&sr=8-6&keywords=fan+splitter
https://linustechtips.com/topic/640002-case-fan-connectors/#findComment-8252472
If you have only 1 fan you should ALWAYS put it top rear as exhaust.
Thanks
I would recommend buying a fan splitter and running them both off the motherboard.
https://linustechtips.com/topic/640002-case-fan-connectors/#findComment-8252481
1 minute ago, ChichoDB said:
You have the CPF02 in that link, get the CPF01 instead. the CPF02 will split 1 into 3, seeing as you have only 2 fans, you only need 2 connections. But yes, it will work.
Get the CPF01
https://linustechtips.com/topic/640002-case-fan-connectors/#findComment-8252488
What fans do you have?
https://linustechtips.com/topic/640002-case-fan-connectors/#findComment-8253474
