$600 Light Gaming/Programming/General PC
I wouldn't call the i3-6100 an upgrade to the i5-2300, bit more of a sidegrade.
You're spending a big chunk of your budget on Windows. You Don’t Need a Product Key to Install and Use Windows 10
I'd do this
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard ($64.89 @ OutletPC)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory ($59.99 @ Adorama)
Storage: PNY CS1311 120GB 2.5" Solid State Drive ($39.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: MSI GeForce GTX 950 2GB Video Card ($124.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($39.98 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($47.98 @ Newegg)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($13.99 @ Newegg)
Case Fan: Kingwin CF-012LBR 40.0 CFM 120mm Fan ($3.98 @ OutletPC)
Total: $623.27
Generated by PCPartPicker 2016-08-06 15:41 EDT-0400
In fact, if you're not going to store that many big fat games, you can go SSD only.
