Hi, i have a custom made PC specs: 1.5 years old
i7 4790k with a stock cooler.
gtx 970 gigabyte g1
z97- pro gamer
16gb ram 1866 mghz
w10 pro
Lately while gaming i started getting BSOD very frequent, i tested all my  hardware and is something like this:
GPU: max 80% *C no crashes
RAM: no crashes
CPU: 100% *C  on more then 80% load.
The BSOD Check code is : 0x00000124   From what i read is a CPU overheating issue  http://imgur.com/a/PIK80
Im not running any overclocks and my cpu dosen't crash while running PRIME95. I will let it run for a couple of hours to see.
I only get crashes while playing Ark:Survival evolved/other games and doing something else on my 2nd monitor. (youtube/movie)
Should i be trying to make any changes or just swap the stock cooler.
What Air/Liquid cooler you recommend, im not planning to overclock - I am thinking of 212 hyper evo. or a noctua on a same price range or cheaper.
https://linustechtips.com/topic/638345-cpu-problems-bsodair-cooler-advice/
gtx 970 gigabyte g1
16gb ram 1866 mghz
w10 ultimate
RAM: no crashes
Get a hyper 212 or a Cryorig H7, Best bang for the buck Air coolers. Definitely seems like an overtemp issue. When gaming, you get up to 100c you say?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Yep, and i checked all my BSOD files.. same  check code for the CPU overheat. I updated all my software before doing the tests.
My biggest answer is why i dont crash while running Prime95... maybe is a powersupply issue ? im confused Il run funmark at the same time
