Low Benchmark Scores! Help? :D
Go to solution Solved by xAcid9,
2 hours ago, Joey96 said:
So mine would be underperforming, if I OCed it and it still was under 4k?
1 hour ago, Joey96 said:
So, I just did the FireStrike, and my GPU got a score of 20642, is that something to worry about, or all good? :D
Nah, you're good.
Hey Guys!
So I know that my CPU i5-4460 was going to bottleneck my GTX 1070 G1 Gaming, but I still got it, and are doing a CPU upgrade later when possible.
But right now, I just want to make sure, that my score is caused by the lack of CPU power, and not GPU problems?
In Valley I got a score at 3958, this isn't because I got a defect card right? :D Thanks!
https://linustechtips.com/topic/635940-low-benchmark-scores-help-d/
Not familiar with Valley scores, have you done a FireStrike bench yet?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
2 minutes ago, JJVGaming said:
that sounds right. did you oc? getting above 4000 requires memory and core clocks
Yep, i cranked everything up, until fragments and program not responding began. I guess the program not responding is because of my CPU? Because my higher memory only caused my benchmark to go black screen, but no fragments, so with a better CPU I should be able to go higher?
4K is the normal score for GTX1070 iinm.
Nah, you're good.
