Hey guys.
I've decided to build my first Gaming PC. I was recommended to come here and seek advice from you guys!
So here's the situation:
Budget: $1,000
Experience with building PC's: Close to none
Expectations: 1080p video quality, good-to-above average frame rate
Thank you in advance for your help in building my first gaming pc!
https://linustechtips.com/topic/635195-building-first-gaming-pc/
need any keyboard/mouse, monitor, OS?
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199931
Just now, jeffgamer94 said:
Yes I would like to include that into the budget! These don't have to be top-tier, just good enough
Do you want to Overclock?
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199943
I think that means overpower? I don't know if that is good or bad
Overclocking means tuning the CPU frequency to, theoretically, boost performance.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199951
That's not exactly true. Overclocking is when you have your CPU, GPU, or even RAM go faster than their normal, rated speeds. Generally this is pretty safe of you don't go crazy with the voltage and watch the temps.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199955
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.99 @ Newegg)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard  ($77.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($60.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($59.94 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Zotac GeForce GTX 1060 6GB AMP! Edition Video Card  ($279.99 @ SuperBiiz)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($64.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($35.00 @ MicrosoftSoftwareSwap
Monitor: Acer G227HQLbi 21.5" 60Hz Monitor  ($102.00 @ B&H)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($31.48 @ B&H)
Total: $1020.84
Generated by PCPartPicker 2016-07-30 09:19 EDT-0400
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199957
get your OS from reddit for $20-30.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ Newegg)
CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler  ($19.99 @ Newegg)
Motherboard: ASRock Z170A-X1 ATX LGA1151 Motherboard  ($91.99 @ SuperBiiz)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR4-2400 Memory  ($59.98 @ OutletPC)
Storage: AMD Radeon R3 240GB 2.5" Solid State Drive  ($59.54 @ NCIX US)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  ($249.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Rosewill 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Monitor: Acer H226HQLbid 21.5" 60Hz Monitor  ($99.99 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator - OEM Wired Gaming Keyboard w/Optical Mouse  ($19.99 @ Newegg)
Total: $1003.93
Generated by PCPartPicker 2016-07-30 09:24 EDT-0400
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199977
I suggest using the website called PC parts picker. it gives you compatibility and pricing information regarding your build.
Noetheless you could be looking at an
i5 6600/K
z170 of your choice
8/16 gb ram
gtx 1060
~500 W PSU
windows 10 home
the rest depends on you. this config should give you pretty decent performance at 1080p :)
Powerhouse: i7 5960X, RVE, 64GB 2400Mhz DDR4, GTX 1080ti SLI, Intel 750 400GB boot, 850 EVO 1tb storage, AX1500i
proto-Powerhouse: i7 3930K, RIVE, 32GB 2133 DDR3, GTX 980ti SLI, 850 EVO 1tb boot, barracuda 4 tb storage, HX850i  ded RIP
Work in progress: Powerzen: R7 1700, X370 Taichi, 32GB, gtx 1050ti (temporary), 850 evo 1tb, Hx 850i
Unraid NAS Server: i7 5820k, X99E-mitx, 32GB 2133 DDR4, THE MIGHTY GT 710 (WITH GOLD PLATED HDMI!!!!!), 3x 10 tb drives, 250 gb ssd cache, Antec 550W PSU, Node 304
Early 2015 Macbook Retina pro 13"
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199983
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($134.99 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 R5 ATX AM3+ Motherboard  ($81.98 @ Newegg)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($58.99 @ Newegg)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive  ($42.99 @ Adorama)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.49 @ OutletPC)
Video Card: Sapphire Radeon RX 480 8GB Video Card  ($269.99 @ B&H)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($64.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($72.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($83.89 @ OutletPC)
Monitor: LG 23MP47HQ 23.0" 60Hz Monitor  ($129.99 @ Newegg)
Total: $1020.76
Generated by PCPartPicker 2016-07-30 09:27 EDT-0400
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199991
Would you guys recommend me attempting to complete the build myself or possibly taking into a store for them to build it?
do it yourself. it is free and nothing harder than putting together lego bricks :). My first bulid was one with a custom loop and it was perfectly fine
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199992
Awesome! Thank you for the advice! Looking forward to building!
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199996
Definitely build it yourself. It's a great experience and you'll learn a lot from it.
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8199997
i5 6600/K
z170 of your choice
8/16 gb ram
gtx 1060
~500 W PSU
windows 10 home
IMO if the budget isn't quite around $1000, AMD is better bang for your buck.
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200002
Will do! Do different build parts affect the building process? Or can I watch a certain video and it's the same steps but different hardware?
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200005
Most builds will be the same as any other. Follow any of Linus' build guides and you should be fine.
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200014
Yeah I agree but I always recommend newer over older, not picking sides here but personally, I would go with the 1060, you are free to disagree :)
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200015
They can affect it slightly, but for 99% of the process it's near identical across your build and one on YouTube. If you choose the one with the i5 6500 and GTX 1060, most how to build your PC tutorials on YouTube should be the exact same process as your build.
If you encounter any problems or issues while building your PC, just come back to this forum and post a new topic and there will definitely be people who will help you out with your build! :)
Good luck!
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200021
If you encounter any problems or issues while building your PC, just come back to this forum and post a new topic and there are sure to be people who will help you out with your build! :)
Good luck!
Thank you very much! I'm leaning towards the intel cpu. Looking forward to building this thing!
This forum has been extremely helpful and quick. Will check back if I have any questions in the future!
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200032
Building your very own computer is a great accomplishment and one worthy of pride. Enjoy building your system!
crap wrong quote... but you get the idea :P
https://linustechtips.com/topic/635195-building-first-gaming-pc/#findComment-8200045
