Would like to make a pic for gaming and graphic designs and programming(light)
budget is 1000€-1200€
live in Europe
i do need a monitor and if the budget fits I would not say no too a new keyboard and mouse
This is my first pc build and probably be building it in around the 6th of August
https://linustechtips.com/topic/632766-new-build-help/
I dont know what kind of games you play, but this should suffice.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (€346.85 @ Amazon Deutschland)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€36.40 @ Amazon Deutschland)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  (€141.18 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  (€68.99 @ Amazon Deutschland)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (€97.74 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€49.95 @ Amazon Deutschland)
Video Card: MSI GeForce GTX 1070 8GB Video Card
Case: NZXT S340 (Black) ATX Mid Tower Case  (€80.43 @ Amazon Deutschland)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€183.59 @ Amazon Deutschland)
Total: €1005.13
Generated by PCPartPicker 2016-07-26 13:26 CEST+0200
you can opt to choose 8GB version for the memory.
I choose the K version, so you can have fun with overclocking later.
Edited by bobang
change the ppp url
CPU: i5 4690k 4.3Ghz | MB: MSI Z97 Gaming 5 | Cooling: Cryorig H5 Ultimate | RAM: Hyperx Fury 16GB | GPU: Sapphire R9 380X | PSU: Seasonic X760 | Case: S340
https://linustechtips.com/topic/632766-new-build-help/#findComment-8168004
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (£299.00 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£30.99 @ Ebuyer)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  (£85.60 @ CCL Computers)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  (£61.91 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£72.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.99 @ Ebuyer)
Video Card: MSI GeForce GTX 1070 8GB Video Card  (£433.48 @ BT Shop)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£58.65 @ CCL Computers)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Total: £1155.58
Generated by PCPartPicker 2016-07-26 12:11 BST+0100
You would be better off using the German pcpartpicker as the op's budget is in Euros. Also 1200 Euros is around £1000GBP.
https://linustechtips.com/topic/632766-new-build-help/#findComment-8168024
My bad, thanks for the info @lee32uk
already change the pcpartpicker list.
https://linustechtips.com/topic/632766-new-build-help/#findComment-8168051
No problem, but also be careful of things that have no price listed...such as the GTX 1070 xD
With this budget I don't think it will allow for an i7 and GTX 1070. An i5 (Or Xeon) and an RX 480 is probably more realistic, as he also needs a monitor (And mouse/keyboard if it fits).
https://linustechtips.com/topic/632766-new-build-help/#findComment-8168064
wow, how can I missed that!
let me try this thing again xD
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (€246.82 @ Mindfactory)
Video Card: Sapphire Radeon RX 480 8GB Video Card  (€275.00 @ Amazon Deutschland)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  (€87.84 @ Mindfactory)
Total: €986.61
Generated by PCPartPicker 2016-07-26 13:52 CEST+0200
or this non "K" version
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  (€226.34 @ Mindfactory)
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  (€114.14 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  (€46.59 @ Amazon Deutschland)
Total: €916.69
Generated by PCPartPicker 2016-07-26 14:02 CEST+0200
and the rest of the budget can go to the monitor+peripherals(if possible)
https://linustechtips.com/topic/632766-new-build-help/#findComment-8168166
Total: €1005.13
Wow that's a fine build ?
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169114
please ignore my first build suggestion, i didn't include the 1070's price in that. LOL
instead checkout the RX 480 build, hope it helps
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169136
Total: €1005.13
4 hours ago, MVPernula said:
http://pcpartpicker.com/list/NNcx6X
If you want a better PC go with the one above, my build allows a monitor as well. I would however recommnd going for the better PC and adding a monitor later.
Thank no you guys so much for the replys I really appreciate it but In your opinions which of the build is better of them all ?
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169166
PCPartPicker part list: http://de.pcpartpicker.com/list/HcXRkT
Price breakdown by merchant: http://de.pcpartpicker.com/list/HcXRkT/by_merchant/
CPU: Intel Xeon E3-1230 V5 3.4GHz Quad-Core Processor  (€253.39 @ Mindfactory)
Motherboard: Gigabyte GA-X150-PLUS WS ATX LGA1151 Motherboard  (€116.69 @ Mindfactory)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  (€68.38 @ Amazon Deutschland)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  (€463.08 @ Mindfactory)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  (€87.89 @ Amazon Deutschland)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€86.31 @ Amazon Deutschland)
Total: €1223.43
Generated by PCPartPicker 2016-07-26 18:58 CEST+0200
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169655
Total: €1223.43
It's a good build only problem is I can t fit a monitor into it then I like the 1070 in there but I need a monitor within that budget
but if I was to get a cheaper mobo, smaller ssd and cheaper case I might be able to fit it in
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169765
3 minutes ago, Caolan.Kelly said:
It's a good build only problem is I can t fit a monitor into it then I like the 1070 in there but I need a monitor wishin that budget also
PCPartPicker part list: http://de.pcpartpicker.com/list/HzJn7h
Price breakdown by merchant: http://de.pcpartpicker.com/list/HzJn7h/by_merchant/
Video Card: MSI GeForce GTX 1060 6GB ARMOR OC Video Card  (€324.90 @ Amazon Deutschland)
Monitor: Dell SE2216H 21.5" 60Hz Monitor  (€121.25 @ Amazon Deutschland)
Total: €1206.50
Generated by PCPartPicker 2016-07-26 19:18 CEST+0200
The 1060 will be perfect for 1080p.
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169790
Total: €1206.50
Alright cool thank you :) of the builds in this then would you believe yours to be the best then or what do you think. Not that I doubt yours is a great build I'm searching for the best and if you think yours is I'll believe you but if you think another is more powerful I'd like your opinion on it ?
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169806
Well the parts in my build will perform better than the ones from the other builds, besides the first one, but that didn't include the price of a GTX 1070 so it would have been over your budget.
https://linustechtips.com/topic/632766-new-build-help/#findComment-8169832
Alright cool thank you very much :)
https://linustechtips.com/topic/632766-new-build-help/#findComment-8170118
Total: €1206.50
Indeed this one is better, cant go wrong with it.
1060, ssd, 16gb ram + monitor.
https://linustechtips.com/topic/632766-new-build-help/#findComment-8173166
18 hours ago, Caolan.Kelly said:
Yup that's great setup too. I see youre going with RX 480 to squeeze in dual monitor inside your budget.
https://linustechtips.com/topic/632766-new-build-help/#findComment-8185632
