im looking to go to a SFF build for my next upgrade and im a bit of a nut when it comes to watercooling (gotta have at least 2 280 rads) so naturally ive been smitten by the NZXT manta. i was wondering if it is possible to mount 140mm fans on the outside of the frame at the front and top without having to forgo the front fan filter? also what is the average space for reserviors on the mounting bar in the case with a full length gpu installed?
wan
https://linustechtips.com/topic/632086-nztx-fan-mounting-question/
Take a look at this for some ideas and for spacings
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
this video is what convinced me to go sff but im going for a pump res combo unit (the EK-XRES 100 Revo D5 PWM)  and im not sure if that will fit with only an extra 50cm for the pump. also the video tells me nothing for my initial question as he is using 120mm fans rather than 140mm. i also now need to know if it has room between the psu shroud and a gtx1080 block from ek for a 90 and a fitting for 12mm hardline.
wan
I cant see any way of mounting a res pump combo in this case. The way kyle does it seems to be the only way to fit a d5 pump.
here is an example of someone used a ddc pump without a front rad
as for the fans
And up front we see the pre-mounted front fans, and also see that the area is recessed to allow installation of thicker fans or a radiator behind the front panel.
View Full Size
View Full Size
Here I installed the thick Corsair H105 liquid cooler, and the radiator still easily fit under the upper panel.
So the fans are not an issue
This is the only example i can find of someone using a 90 in the way you intend. The fitting appears to be touching the PSU shroud. So it could come down to the fittings you use
