6 minutes ago, Veldro said:
Hi guys I'm trying to build a $700 pc to play almost every game, for this I made this build.
Rate it and made some comments about some things I might be missing.
Pcpartpicker: http://pcpartpicker.com/list/8xjykT
I would recommend getting a 1060 instead of an RX 480. I say this because the 1060 outperforms the 480 and is around the same price range.
I commend your usage of a good PSU, but you'd be better off on an i5-6500 for 1080p
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($51.99 @ SuperBiiz)
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($34.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Sapphire Radeon RX 480 8GB Video Card  ($269.99 @ B&H)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($56.94 @ Amazon)
Total: $701.37
Generated by PCPartPicker 2016-07-24 20:46 EDT-0400
Computer Specs:
Not actually around the same price range, it's unavaliable for less than $300
Computer Specs:
7 minutes ago, darkninja8888 said:
It came out less than a week ago just wait the price should be the MRSP in a couple weeks
And by that time RX 480s will have dropped prices as well.
No sir, I will not take waiting as a justification. Anyone can wait to get better bang for buck not just on nvidia GPUs
Computer Specs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487260&ignorebbr=1  Boom.
1 minute ago, darkninja8888 said:
Out of stock. Try again.
Computer Specs:
Total: $701.37
I like this build better then the original build using fm board and the FX AMD cpu. The i5, however being locked, will perform in my opinion nicer (maybe not as many FPS) but will overall be nicer to use generally.
I may consider in your case to get 1x8GB DDR3 Dimm, so you can upgrade to 2x8 and so on. Unless you don't see yourself doing much upgrading.
I also would conisder the GTX 1060 as well, but thats just my opinion (wait for it to be stocked, worth it)
It doesn't look like you have the cash, but I prefer a small SSD boot drive and a larger PSU for more comfort room.
Overall nice build though!
Just now, darkninja8888 said:
I'm just saying if you wait you will be getting better bang for your buck.
Yes, because you will be able to buy a $200 RX 480 and use the rest of the cash for a much needed SSD
Computer Specs:
If you were to do that trade, I would stick with the 480 and get the SSD. The difference between it and a HDD it night and day!
or save some more money and get exactly what you want
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard  ($64.98 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($54.99 @ NCIX US)
Video Card: Sapphire Radeon RX 480 8GB Video Card  ($200.00)
Total: $699.36
Generated by PCPartPicker 2016-07-24 21:08 EDT-0400
This build with a 4GB RX 480 is best bang for buck imo
Computer Specs:
Total: $699.36
Yeah, looks good. I have never ran a stock cooler on a GPU before (besides aftermarket GPUS) so i wonder how thermal throttling will affect your performance.
I think you will enjoy this build. Decent PC for 1080p gaming
RX 480's cooler is meh, you can survive on it, but the hape is that at least one custom-cooled custom PCB 4GB 480 goes for just over $200
Computer Specs:
