Soundcard not detected!
Go to solution Solved by Volbet,
Well, the Asus drivers suck anyway.
I would recommend you try the UNI driver
While it's far from perfect, it's still better than the Asus drivers.
As the title says my system can't detect my soundcard, which is wierd cause it worked previously.. So basically the problem started after i unplugged a fan from my computer, which was connected to a molex cable with a mini-molex at the other end connected to the soundcard (Asus Xonar D2X) i unplugged the molex cable, but put it back in again (still connected to the soundcard). Suddenly then i turned on my PC the card was not found in playback units neither in device manager, also other than putting the molex in and out of my PSU, i did install a midiboard which came with the D2X, other than that i havent done anything to affect the system. Also if the problem is that im missing a driver to the soundcard, i can't seem to download it from the Asus Support site, it just tells me the download link DNS-address doesnt exist. (I have not yet contacted Asus as i was hoping to get help quicker here and Asus require me to write in alot of information just for a e-mail to be sent)
And just in mind.. i really dont want to put the card in some other PCE slot, it has allways worked in its current location until now.
More information: Yes the soundcard has power, all of it's lights are on. Unplugging the midiboard doesn't seem to help at all. Yes i do not have a driver for it, writing this i've come to realise that's msut likely the problem, but as stated above the download link for the driver doesn't exist, and plugging in a cd-rom reader just to install an outdated cd driver doesn't seem viable.
This is my first time at the LinusTechTips Forum and i hope that i dont disturbe it somehow and that i can get help ASAP. ^_^
https://linustechtips.com/topic/629691-soundcard-not-detected/
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/629691-soundcard-not-detected/#findComment-8133760
