3 minutes ago, PCHelp2015 said:
so I've just installed the Pure Rock CPU cooler, and the fan wasn't attached to it. I'm new to all of this, how do I attach the fan to the 'heat sink' (I think it's called :D)
I believe the Pure Rock has little metal brackets that attach the fan to the fins.
th?id=OIP.Mb03113a9d510a0f9a9883fb78c0ae
https://linustechtips.com/topic/627330-idiot-help-once-again/#findComment-8093216
Thanks I can see these are the parts that are left for me to add. Seems a little confusing still - I've searched for YT videos can't find anything.
https://linustechtips.com/topic/627330-idiot-help-once-again/#findComment-8093233
Does this look correct to you? I didn't use two silver clamps or whatever they look like (bottom right of pic). Does this matter? image.jpeg
https://linustechtips.com/topic/627330-idiot-help-once-again/#findComment-8093290
...as long as the fan is secure it will work fine.  You can use tape if you want xD
..jk, don't use tape.
https://linustechtips.com/topic/627330-idiot-help-once-again/#findComment-8093311
