I am currently interested in building my own computer(with 0 knowledge). What i need help is the most cost efficient/powerful components i can purchase in the price range. I will mainly be using my computer for CS:GO, H1Z1, LoL etc. Intersted in a good GFX card as well as SSD. As well as being used for college school work. I live in AZ so i will also need a recommendation on computer fans to keep everything cool. Anyways i would appreciate it if someone can inform me on all components i need to buy to get the most bang for my buck while also being compatible with one another so i dont come across too many issues when building my computer for the first time. Thank you
https://linustechtips.com/topic/625961-600-700-computer-buildplease-help/
I'll edit this post when i can get a link for the build
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
also if there is a prebuilt comp with a good setup i will be intersted in that too. The build part would come as fun but i mainly just want a new computer whether it be prebuilt with good components or i build my own.
Use https://pcpartpicker.com/ to keep track of things and it will tell you about prices and whats compatible with what parts
CPU: Intel i5 3570k 4.2GHz with Corsair H100 RAM: Corsair 16GB (4x4) SSD: Samsung 840 120GB HDD: Seagate Barracuda 1TB GPU: Strix GTX 1080
PSU: OCZ 650W CASE: Fractal Define R5
https://pcpartpicker.com/user/MelchiorVester/saved/#view=RKNXsY
https://pcpartpicker.com/user/GrimIcarus/saved/H86v6h
Dendrotoxin
Perripherals
Prebuilt is no a good idea when it comes to gaming and ive seen some really overpriced shit that  isnt even for gaming Ahem Mac Pro
Dendrotoxin
Perripherals
43 minutes ago, QueenObama said:
I think this would work (this is fred From Steam) http://pcpartpicker.com/list/gkmWD8
sorry im late but i would like to point out that in the build you chose to link you added an FX series processor from AMD. in terms of Single Threaded Performance (which most all games benefit from) any Skylake Pentium would be a better choice. i do not, in any way mean to undermine you but i ask you to consider my suggestion
the 1060 will most likely not reach MSRP until the 2-3 months within the release as that is the case for the the 1070's current pricing
Dendrotoxin
Perripherals
The Only thing is that A motherboard would need to be changed which will cost more and I have the same Cpu and Im fine, Also he doesnt play many cpu intesive games but also The minimum Price for the Gtx 1060 is 300 on july 19th
Listen, Smile, Agree.
Then do whatever the fuck you were going to do anyway
6 minutes ago, QueenObama said:
he said he was looking for components so i assume he hasnt bought one. my main concern is upgrade path if he decides to do something and i  highly doubt an aftermarket 1060 will follow the MSRP, just look at the 1070 and some 1080 s
Dendrotoxin
Perripherals
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.99 @ B&H)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.88 @ OutletPC)
Memory: Crucial Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($30.98 @ Newegg)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($44.00 @ Amazon)
Video Card: MSI Radeon R9 390 8GB Video Card  ($254.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($64.99 @ Directron)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $703.82
Generated by PCPartPicker 2016-07-13 18:36 EDT-0400
Total: $703.82
I Like the use of the Intel, but I think the R9 is not the right card,
it's beeing released at 300$
it is but i doubt it will sell at 300$ the MSRP for the GTX 1070 was 400 and found low end aftermarked at 450 to 750
Dendrotoxin
Perripherals
