So im torn between the Evolv ITX and the Fractal Denfine Nano S, im defenitly planning on getting an extra fan to help aircooling
The Evolv ITX:
- slightly more space between PSU and GPU + a metal plate between the two
- comes with one 200mm Fan for the Front
The Define Nano S
- comes With a 140mm front and a 120mm rearfan
- space for another 120mm fan at the bottom
Which Setup will perform cooler?
https://linustechtips.com/topic/624133-which-itx-case-will-be-cooler/
