Unibeast problems
Go to solution Solved by Guest,
Hi,
LTT forums do not allow Hackintosh content. Best advice would be to take this to TekSyndicate forums or TonyMacX86 forums.
It sounds like you need to format your OS drive for GUID format and make sure your installer USB drive is set to master boot record format.
That's about all I can say, probably too much. Sorry :\
I am trying to create a usb drive to install os 10.11.5 (for a hackintosh) with UniBeast but when unibeast tries to format/create the usb a message pops up saying "make sure neither os x install esd or os x base system are mounted on your drive" does anyone know what this means or how to fix it???
https://linustechtips.com/topic/623965-unibeast-problems/
Hi,
https://linustechtips.com/topic/623965-unibeast-problems/#findComment-8059818
1 hour ago, IAmLamp said:
Hi,
thx ; )
https://linustechtips.com/topic/623965-unibeast-problems/#findComment-8060143
Guest
