Hey sup !!! Need your help please !!!
I have a motherboard z170 Gaming g1 with a intel hd graphic card integrate and i try to use it but when i open the intel control panel installer he won't open is just loading and nothing happened i don't know why all the drivers is installed !!!
Please Help me !!!
Thanks in advance !! And have a great day !!
https://linustechtips.com/topic/623049-intel-hd-control-panel-wont-open/
1 minute ago, legitt199 said:
because im waiting to receive my two gtx 1080 sli !!! i dont have graphic card for now !!!
Don't bother messing with the control panel? If you want to change settings, do it with the monitor. Also, your 6700k will bottleneck them.
USEFUL LINKS:
PSU Tier List F@H stats
I dont have access to the control panel i cannot install .... he wont open !!
Don't think so.  A quick search of FireStrike Extreme results of 6700k and 6950X 1080 sli systems, the graphics scores are very similar in the 22XXX range for both processors.
Because bottlenecking in both systems? The 6700k has enough cores/threads for that to not be an issues and the 6700k has higher IPC.
USEFUL LINKS:
