System and implementation specific - which means it can return anything.
A system can support multiple threads per processing unit, or access to (some) processing units can be denied to your program by the OS so the result need not match the amount of cores in your CPU.
2 hours ago, zMeul said:
Return value
number of concurrent threads supported
it should return 8, test it
I can't test it, as I don't have a hyper-threaded CPU... But thanks!
Nothing to see here ;)
The results as expected with an i7-5820k. However std::thread::hardware_concurrency is platform specific and implementation specific meaning that the results can be different across OS's and hardware.
int  main()
	std::thread t;
	int numThreads = t.hardware_concurrency();
	std::cout << "Number of Threads: " << numThreads << std::endl;
	std::cin.get();
	return 0;
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
int  main()
	std::thread t;
	std::cin.get();
	return 0;
Thanks a ton - that was really helpful!
Happy to help. :)
