PC won't turn on, help
Go to solution Solved by Chace,
Hey all final update: I took my PC to the store and they said the motherboard was busted so they replaced it under warranty. Thanks all for help, its working great! Appreciate all your help! :) @straight_stewie @Silencer @YoFavRussian @kebo2015
5 minutes ago, YoFavRussian said:
And I imagine that it fixed itself last time? That is quite interesting, maybe check the power button leads that connect to your MB.
 @YoFavRussian yeah it was the most bizarre thing, I left it and then went out and when I came home it was all lighting up and fans spinning when I walked it.  Worked fine all that day and then I shut it down to sleep and now its not working again.
https://linustechtips.com/topic/622142-pc-wont-turn-on-help/#findComment-8023540
Just now, Chace said:
Ok strange, I unpluged everything and left it with no power for about 30 minutes and I came back and replugged and it turned on fine, wtf this is the weirdest thing
Next time this happens, instead of unplugging, I want you to push the cable inwards only. This will tell us if: 1) it's always plugged in all the way, or 2) there isn't a problem with the power cable or the connector on the machine.
ENCRYPTION IS NOT A CRIME
https://linustechtips.com/topic/622142-pc-wont-turn-on-help/#findComment-8023639
https://linustechtips.com/topic/622142-pc-wont-turn-on-help/#findComment-8031130
