Hello everyone I currently have a Phantek Enthoo Pro case and it's great and all but it's too big IMO. I've had it for a while and I wanna get a new case. I've been looking for nice good quality small case. Like a mATX case and I'm looking for recommendations.
I've been looking at the Corsair air240 and bitfenix prodigy. Those are the only ones I've seen that look great. I do plan on buying another mobo so it can fit. I also have a AIO water cooler with a 360m rad and I will also buy another cooler so it can fit. What cases do you recommend? Something that looks nice, great quality, great cooling, and small :) Budget is under $200 but if the case is really good and is a little over $200 that's fine.
Thank you!
https://linustechtips.com/topic/618364-looking-for-a-good-small-case/
What size is your motherboard so we know what size of cases are fair game. I'm a fan of the 400C from corsair. looks bomb af imo. Lots of people love S340 (not sure if it can house 360) and H440 cases (H440 is a bit on the larger side). Others love the Define S or Define R5.
What sort of aesthetic are you looking for?
Oh poop you DID say mATX. okay, throw all those suggestions out the window haha.
Thermaltake Core V21 looks pretty good and should house what you need imo. I'm no expert on mATX cases though, so I dont know what there is out there on the market atm.
If you're getting a new motherboard and dont mind going ITX, the Corsair 760T looks pretty cool imo.
Thermaltake Core X2 is also a decent chassis. In fact check out the Thermaltake Cube cases, they're all fairly similar, somewhat small, and have alot of radiator support.
