45 minutes ago, Gazeley said:
@BringBackLCT @mathmeister Yeah I'm definitely not over clocking! Ok so how much would I save a lot by building it myself?
Depends where you go but don't buy it from somewhere like iBuyPower, it's nearly the price of an alienware. Just find someone local that will build it for you.
https://linustechtips.com/topic/618335-pc-building-help/page/2/#findComment-7983311
Well, build the PC you want on PcPartPicker.com then go to staticice.com for the cheapest price (it searches all the major and some minor retailers)
"AMD is bringing DDR5 to the mainstream with their all new FX 8450 and FX 9690 Zen processors. Check out the link in the video description to learn more."
  • CPU
    Intel Core i5 4690K
  • Motherboard
    MSI Z87-I Mini-ITX
  • RAM
    16gb Corsair Vengeance DDR3-1600
  • GPU
  • CHANGING
  • Case
  • BitFenix Comrade Window Black/
  • Corsair 250D
  • Storage
    Hectron X1 60gb SSD "The China", Hitachi 500gb 7200rpm
  • PSU
    Corsair TX650
  • Cooling
    Hyper TX3
  • Keyboard
    AULA F2012 Mechanical
https://linustechtips.com/topic/618335-pc-building-help/page/2/#findComment-7985926
4 minutes ago, Gazeley said:
@BringBackLCT Thank you very much! You've been a great help however do you happen to know of any sites that will test to see if all the chosen components work together or even fit within the case?
That would be PC Part Picker my friend. It will come up with a warning if something doesn't work. The only thing that it doesn't check as far as i am aware is the GPU length vs case length and cooler height vs case width.
  • CPU
    Intel Core i5 4690K
  • Motherboard
    MSI Z87-I Mini-ITX
  • RAM
  • GPU
  • CHANGING
  • Case
  • Corsair 250D
  • Storage
  • PSU
    Corsair TX650
  • Cooling
    Hyper TX3
  • Keyboard
https://linustechtips.com/topic/618335-pc-building-help/page/2/#findComment-7985973
Also, let me know how it goes by PMing me on here. I would like to see what you end up doing. Thanks!
  • CPU
    Intel Core i5 4690K
  • Motherboard
    MSI Z87-I Mini-ITX
  • RAM
  • GPU
  • CHANGING
  • Case
  • Corsair 250D
  • Storage
  • PSU
    Corsair TX650
  • Cooling
    Hyper TX3
  • Keyboard
https://linustechtips.com/topic/618335-pc-building-help/page/2/#findComment-7985976
20 hours ago, Gazeley said:
@BringBackLCTOk I'm going to have to replace the case in order to get a case with 3 USB ports will I need to change the motherboard as well?
Do you 100% need 3 usb ports on the case when the motherboard has so many? But if you do change the case, make sure its not an ITX case and its a Micro-ATX or ATX.
  • CPU
    Intel Core i5 4690K
  • Motherboard
    MSI Z87-I Mini-ITX
  • RAM
  • GPU
  • CHANGING
  • Case
  • Corsair 250D
  • Storage
  • PSU
    Corsair TX650
  • Cooling
    Hyper TX3
  • Keyboard
https://linustechtips.com/topic/618335-pc-building-help/page/2/#findComment-7991710
