see all the faded white lines? this sometimes happens if i close a app to quick or game crashes on me not sure what it is. i have tried DDU to reinstall drivers that didnt fix it but when i use print screen it doesnt pick it up so im not sure if its a graphics card issue or my monitor
i7 12700k/Asus Tuf z690/32GB Corsair Dominator RGB 3200MHZ/EVGA 3080 Ti FTW3 Ultra/Samsung 980 Pro 1TB/Asus 2540x1440p 165hz Gsync/Acer 2560x1440p G Sync 144hz
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/
7 minutes ago, Ajaydev Singh said:
Can you try using a another monitor? It can but a monitor issue.
unfortunately this is my only monitor i have. altho it seems restarting my pc fixes the issue so theres that. using a 1080 FE with 368.39 drivers and it did this before i overclocked so i know its not that. and i also dont have any ways of forcing it to occur it just happens randomly where those lines shoot accross my screen whenever i scroll or open a program until i restart pc. i had to use my phone to even capture the image as print screen wouldnt capture it
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7981976
This could but ghosting issue with the monitor, Linus did a video on  Techquickie
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7982037
any way to fix?
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7982062
Well 1 way is monitor software update which I dont think many support. other is rma if your monitor still warranty
it is brand new lol
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7982114
I get same artifacts when overclock to much my 7650m's memory, Lots of lines.... Try connecting your monitor to integrated graphics see what happens
HP Probook 4540s
MoBo: HP 17F6 HM76 Panther Point
CPU: Intel Core i5 3210M 2.5Ghz
RAM: 8Gigs Hynix HMT DDR3-1600
GPU: AMD Radeon 7650M 2G (OC, from stock 500Mhz to 570-590Mhz)
Kingston SSDNow UV400 240gb
Standart 1366x768 16:9 Built in display
Mouse: Acme MA06 (it is cheap, but in games like GTA V Online, shooting is such good pleasure to own everybody!  )
And 40370mwh battery for outside fun
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7982154
hmm i would try that if i could reproduce it on command which I can't
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7982435
Have another GPU or at least a TV to try on?
Another thought - Overclocking Damage :/
HP Probook 4540s
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7982533
it was doing this before I even overclocked and it is my only gpu and as i have said many times I can't reproduce it on command it is very random and can go days without it happening
Edited by SHADY16
https://linustechtips.com/topic/618294-hmm-wierd-graphics-issue/#findComment-7983581
