Case help.
Solved by wraptor,
3 minutes ago, Aruterisu said:Im looking to buy a case , that is smaller and more compact to mine and was looking at this case.
Enthoo Evolv ITX Mini-ITX Chassis with Window - Black
However , im currently using a 212 evo cooler in my build and was wondering if it would fit this case ; Any help would be appreciated.
Yes it would, the Hyper 212 is 159mm long whilest the case is 230mm, there's around 20mm cablemanagement space so you would be fine.
