Hey gugs.
Im posting from my phone so here we go.
I was playing GTA V on my pc and the screen went white and the audio made that disgusting freezing sound.
I restarted my pc and made it to the login screen. The second I logged into my account the screen had a blue line flicker and the screen went black. After the screen went black it would stay like that for 10 seconds then the PC would restart by itself. I reinstalled Windows and I am able to login to my account now but after like 3 minutes the PC the the blue line thing and freezes then restarts by itself
I need help guys please
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/617376-pc-keeps-restarting-randomly/
3 minutes ago, Goodman2265 said:
Hey gugs.
sounds like an overheat or instability issue. try reapplying TIM on the CPU and reseating the heatsink.
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
Ive been sitting in the BIOS for 10 minutes now and the PC hasnt freezed. CPU temp is 40 degrees
is the CPU OC'd or is it running at stock frequency, also are you using a dedicated GPU or the iGPU. if you can try using differnent ram
Im using a dedicated GPU and it seems fine. I will trying running a single stick of ram tho
My cpu is at stock too
I left the BIOS and window says "Windows didnt load correctly"
Now i can choose options to troubleshoot
There's a couple things you can try, depending on what's going wrong.
Is it storage? Try to get to windows and run chkdsk /f in an elevated command prompt
Is it your RAM? Use another computer to download memtest86+ and make a bootable USB flash drive with it.
Is it your GPU? See if you get the error by disconnecting the GPU and connecting your displays to the motherboard (it will run on integrated graphics).
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
My BIOS doesnt reconizge my first stick of ram
It says Undefined 4096 MB 1600 MHz
All the timings are the same tho
I did chkdsk last night and nothing came up
I did notice my pc would crash when i would go to Windows Update
Now my pc wont make it past the ASUS logo from my mobo. It does the blue flicker and restarts
Im gonna install windows u and see what happens
Windows 7*
Yeah, reinstall windows and once you're done shoot us a mention if you're still getting problems.
Computer Specs:
what ram do you have in there.
