Hi guys,
so these are the parts I have http://au.pcpartpicker.com/list/rnhKZ8
i want to do a custom water loop to cool the CPU and The gigabyte 1080 gaming card.
can anyone help me out with a parts list that would work best with what I have and in that case?
thanks!
https://linustechtips.com/topic/617007-help-with-custom-loop-parts/
14 minutes ago, Dwood180 said:
And I also want to include the motherboard in the loop as it already supports a loop
so
basic parts, no links.
lga 1151 waterblock.
male/female fittings.
tubing that corresponds to fitting diameter
optional(quick disconnects)
d5 pump
reservoir
gigabyte gtx 1080 waterblock
2 minutes ago, skullrebell said:
knowing your case is rather important, since it would let us know what kind of res you could use,
The case should be listed with the parts on the link I provided. It's the Phanteks Enthoo Evolv ATX Tempered Glass one. https://www.pccasegear.com/index.php?main_page=product_info&products_id=35392&cPath=547&utm_source=googlebase&utm_medium=cse&utm_campaign=export_feed#googlebase
Looks like you're pretty much getting everything from EK. You could probably save money by getting a kit from them, then adding a gpu block and a couple of fittings. IIRC one of their kits has a D5 pump res combo.
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
Thanks I'll check out the kits now
6 minutes ago, airdeano said:
missing fittings and some fans..
I have compression fittings on the list somewhere. But fans, I knew there was something I was missing! I have just ordered the case so I want to wait until it arrives before I order the water cooling parts to see what size and how many rads will fit.
10 hours ago, Dwood180 said:
I wouldn't go with the coolant dye.
You risk having a gunked up loop
https://www.ekwb.com/shop/tube-primochill-primoflextm-advanced-lrttm-15-9-11-1mm-bloodshed-red-retail-3m
Get that tubing, drop the coolant dye. Get this to stop bacterial growth https://www.amazon.com/Silver-Coils-Antimicrobial-999-Strip/dp/B00A66HMRC
Look at your cases "specs" and it will list the radiator support.
How often would you have to clean out the loop to avoid the gunk build up from the dye? And if I still got dyed coolant is there any brands that would be better then ekwb ones?
Some people clean it out monthly.
Depends on how much you like doing maintenance
