1. Budget & Location
the buget is 2000$ (American {usd})
location Puerto Rico
2. Aim
General use and gaming
3. Peripherals
A keyboard nothing else
Ok i this build has to be portable , I am building for my Best Friend , he will purchase the parts i will build it
the reason it has to be portable he has to take it from his moms house to his dads house every 2 days!
Insomnia!
Taking down airplanes with gameboys
https://linustechtips.com/topic/61627-small-form-factor-build/
What res is he going to be playing at?
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-840357
Damn, $2000 is a lot.
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($219.99 @ Newegg)
CPU Cooler:  Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler  ($89.99 @ Microcenter)
Motherboard:  MSI Z87I Mini ITX LGA1150 Motherboard  ($139.99 @ Amazon)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($119.99 @ Microcenter)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($84.98 @ Outlet PC)
Video Card:  Asus GeForce GTX Titan 6GB Video Card  ($995.99 @ SuperBiiz)
Case:  BitFenix Prodigy (White) Mini ITX Tower Case  ($69.99 @ NCIX US)
Power Supply:  Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply  ($54.99 @ Microcenter)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($95.87 @ Outlet PC)
Total: $2025.97
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-01 16:29 EDT-0400)
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-840361
Total: $2025.97
Dang! Wait for the R9-290X is you're going to be buying the Titan! Either that, or replace it with a 780 DCU II. :P
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-840366
Looks good to me. An alternative is to go for a 780 and perhaps a better Mobo or something... Just An idea. An if it's matx, how would two 780's compare to one Titan, bearing in mind it's not too much more with a budget like that
OnePlus 6T
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-840423
780 SLI would kill TITAN.
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-840493
wait for the prodigy M (mATX version) and build a system in that, like 4670k, r9-290x, z87 gryphon, kraken x40, 8gb of ram, rm power supply 250gb intel ssd.
Cpu:4670k- at stock.... for now Gpu:r9-280x crossfire Cooler:KrakenX40 MB:mpower SP Ram:8gb hyperX beast
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-840969
it really depends on what you mean by "portable". If your friend is super big it might not be an issue. But one thing that I would recommend is SSDs. You really don't want to be moving HDDs that often, in I assume a car, you could do that with $2k. And if you do get HDDs get a case with hotswap bays so you can just take them out when needed.
-Corsair 750D - MSI Mpower Z77 - 3570k @ 4.21 -Corsair H60- 8GB Corsair Vengeance 2133 Mhz- Corsair RM850 - MSI 780 Lightning -256GB SSD- 2 1TB HDDs - LG 23' Flatron - Razer Death Adder - Ducky Shine 3 Cherry MX Blue - Logitech z506 5.1-
Project - Bloody Lightning
https://linustechtips.com/topic/61627-small-form-factor-build/#findComment-841167
