So, a while back, my little brother dropped my tablet on the ground which effectively broke it. Basically, when I turn on the screen, all I get is black with a thin line that changes colors. (I'll try to upload pictures later if needed.) And basically, I want to fix my tablet so I finally use it again.
The model is the NuVision TM85M3.
And before someone tells me to buy a new tablet, I really can't. Let's just say, I kinda used a lot of favors and money for computers and stuff.
https://linustechtips.com/topic/615570-tablet-screen-problems/
Well...it's a cheap tablet that really isn't cost effective to fix.  You would save a lot of time and trouble just getting a new one.  You may be able to save like $20 dollars by replacing the lcd and digitizer, but it's not worth it at all in my opinion.
Did it crack the digitizer or is it just the lcd that is damaged?
https://linustechtips.com/topic/615570-tablet-screen-problems/#findComment-7951911
Nevermind man, IT IS FOREVER RIP! by the way, recommend any tablets?
https://linustechtips.com/topic/615570-tablet-screen-problems/#findComment-7952052
