Ok should I go for a ek S360 kit for 219$ or ek L360 kit for 260$ or a noctuca dh-14 on bclk i5 at 4.5ghz 1.325 V. I want to keep temps under 70C. Cause in a bclk only the package temps are shown thus I just wanna be sure
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/612960-yes-water-cooling/
4 minutes ago, MJ... said:
The ek s-series will be enough if you dont plan to watercool other components :)
what about if i do watercool other components, like a vega gpu or my vrms. I can add another 120mm
Build
https://linustechtips.com/topic/612960-yes-water-cooling/#findComment-7921499
17 minutes ago, MJ... said:
Than maybe go for the more expensive option :)
THX
Build
https://linustechtips.com/topic/612960-yes-water-cooling/#findComment-7921562
