So my oculus rift finally arrived yesterday. I was so looking forward to playing project cars, so I plug in the wheel and it goes nuts. No left turn, only 90 degrees right. Uninstalled logitechs profiler and removed all traces of it with a Logitech tool as well as manually removing drivers.
Now with the profiler reinstalled, and all settings set to 900 degrees, I have a new issue. The wheel and pedals work, but the wheel, no matter what settings I put in is stuck in 180 degrees mode (90 either way). But worst of all, Windows only recognises it as 180 degrees in the 'game controllers' window. So despite all profile settings set to 900 degrees (global and game specific etc etc) it not the game with the issue, but even Windows itself can't see the full 900 degrees of rotation.
Surely, it's a driver issue, but I've tried everything. I'm getting to the point now of wanting to sell the damn thing and just buy a t300. But the bui.d quality doesn't see, as good.
Any help appreciated.
  • Primary PC (Photo editing and gaming on a 4k Monitor): Intel I7 4790k @4.5ghz @1.2v | 24GB  Corsair Vengeance Ram @1600Mhz | 1x Palit GTX 1080 JetStream| 480GB Crucial SSD | 2x WD Blue 500gb | Corsair RM1000 | Corsair 600t
  • Secondary PC (Gaming and watching films on a 42" 4K LG IPS TV @4k60): Inteli7 4790k | Corsair H60 | Asus H81l-plus ITX | 16GB Kingston Hyperx Beast 1600MHz | 1x GTX 980 G1 Windforce| 1x Samsung 1 TB 850 EVO SSD |Corsair CXM750W | Coolermaster Elite 130
https://linustechtips.com/topic/611371-logitech-g27-issue-please-help/
Just to clarify, does this only happen when the Oculus is plugged in. Only asking because that was the first thing you talked about.
Likely a firmware issue within the controller
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
No I thought that. Its annoying because I've been using the wheel for ages on same software/drivers. Logitech seem to have stopped releasing drivers for the g25/27 after the launch of Windows 10 and there new replacements.
1 minute ago, Davehaslanded said:
No I thought that. Iys annoying because I've been using the wheel for ages on same software/drivers. Logitech seem to have stopped releasing drivers for the g25/27 after the launch of Windows 10 and there new replacements.
Not drivers. They are the connection between firmware and OS
Firmware issues are often more difficult to resolve. Firmware controls the hardware within certain device. A faulty game controller is 99% due to glitched or corrupted firmware, usually caused by an ESD when a person touches it
Roses are red
My name is Roy
I've not had a chance to try with a second PC. The firmware on the g27 isn't upgradable either so there's no quick fix.
Contact Logitech, but from what I can see the two may be unconnected... If you get no joy PM me and I'll see if I can get some clever person at Logitech to help you.
Eyeballs: HTV VIVE  - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E  i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS
Thanks. I ended up ordering a thrust master t300rs in the end. Didn't want to have to wait weeks to diagnose and fix an issue when my rift was mainly bought for sims (and btw, it's amazing).
No worries, as long as you can keep gaming problem fixed :D
I just got a g27 for euro truck and it was working fine but the shifter wasn't so i downloaded the logitech profiler from years ago and the stick works now but the wheel barely works it only goes 90 degrees left or right and its like in turning with a keyboard again but worse.
