I have 24gb of DDr3 installed and my CPU is overclocked to 4.4GHz but when i go to system info i shows 12gb of ram and a max clock of 5.9GHZ. but when i look in the bios or a program like CPUZ it shows the correct info. has anyone had this problem? should i be worried about anything regarding this? i just noticed this issue the other day, and it has not caused any real problems but its still kind weird.
I have the latest bios update and have even done a recovery on windows trying to fix this.
https://linustechtips.com/topic/611014-clock-speed-and-ram-issues/
Open task manager and see what it says under performance for Memory. Does it register all 24gb?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Here is a snap of what it will look like:
https://i.gyazo.com/b2ef24de9803810385bda853eb92f9df.png
Community Standards
"Beast Mode"
remove and reinstall the memory and see if it resolves itself, might just be a seating issue
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Glad it fixed your ram problem, check in your bios that the base clock is set to 100 not 133, if it's 133 that ramps up your 4.4 to about 5.9
desktop
HTPC
