I plan on using a network switch to provide my entire house with wired Internet, however I want to plug a outer into it, and mobile devices to interact with my wired devices (remote mouse, Spotify). How do I program the router to just broadcast the same network that the switch is making, instead of making a new network that only recognizes machines plugged into or wirelessly connected to it
Thanks!!!
https://linustechtips.com/topic/610164-network-switch-and-wireless-devices/
If you plug the wan port of your router on you switch, all the devices connected to the router will be considered connected to the switch
Gaming rig : i5 6600k | EVGA 1070 FTW | 16Go DDR4 HyperX Fury | Intel 600p - WD Black
Laptop : Macbook 2017
Home server : AMD A10 7700k | 2*2TB unraid array + 250GB ssd cache
