First Build ^^
Go to solution Solved by Thony,
8 hours ago, Kami675 said:
hmm, I ended up switching to the Corsair H110i GTX 104.7 CFM Liquid CPU Cooler, what are your thoughts on that cooler?
Best AOI u can get.
Hello everyone, I am getting ready to order parts for my first Build(hopefully by sunday, except the 1080's), I was just posting on here to see everyone's opinions on it and if you have any recommendations such as parts that may be cheaper and work just as efficiently or any flaws that may or may not need correcting. I am not 100% sure on the case I will be using so if anyone has recommendations for an excellent case that would be wonderful. I have around 1900 overall to burn including the keyboard, this does not include additional fans, paste, wires etc as I have extra money set aside for that.
P.S. the 1080 I will be going with is going to be either the STRIX or the FTW I am unsure which I will be ordering(whenever they are officially released)
P.S.S. The monitor I have there is just a monitor I am using until the end of summer when I will be grabbing a ROG Swift
Here is my pcpartpicker list: http://pcpartpicker.com/list/YcBjXH
If you have any other questions i'd be happy to answer them!
thanks in advance,
- Kris
https://linustechtips.com/topic/608959-first-build/
only thing i can recommend is a better cpu cooler especially if you plan to overclock, perhaps an all in one liquid cooler like the h115i
My PC: I7 4770 (3.4Ghz)
32Gb Corsair Xms3 DDR3
Gigabyte G1 Gaming 980ti
Asus Z87-A Motherboard
Samsung 120gb SSD
Seagate 2TB HDD
Aerocool Xpredator Evil Black
http://www.3dmark.com/fs/8502026
https://linustechtips.com/topic/608959-first-build/#findComment-7879889
Cooler is fine but don't expect much overclocking with it.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/608959-first-build/#findComment-7879912
why the founders edition? maybe wait for other brands start launching their custom cooler and also they are cheaper than the reference cooler
p.s they already come out lol
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
https://linustechtips.com/topic/608959-first-build/#findComment-7879944
Thanks a ton for the input, I originally had the H110i as my cooler but someone suggested grabbing the 212 EVO instead >_<
Reread my statements again, I said, " P.S. the 1080 I will be going with is going to be either the STRIX or the FTW I am unsure which I will be ordering(whenever they are officially released)". This are aftermarket 1080's, I never said anything about grabbing a Founder's Edition.
Ah ok, I didn't know that lol, what cooler would you suggest then?
https://linustechtips.com/topic/608959-first-build/#findComment-7882490
Something 2x the price and higher.  But it depends on your desired overclock. AOI watercooler would be best, NH-D14 or 15 from noctua is the best air cooler but its massive....
https://linustechtips.com/topic/608959-first-build/#findComment-7883363
https://linustechtips.com/topic/608959-first-build/#findComment-7883832
Best AOI u can get.
https://linustechtips.com/topic/608959-first-build/#findComment-7885146
