Just a little help
Go to solution Solved by DragonSlayer 159,
1 minute ago, Robert_The_Nigerian said:
So I should be good to upgrade then?
Thanks bro!
Just to be sure this is the card I plan on moving too
https://www.amazon.co.uk/MSI-R9-380-Gaming-Graphics/dp/B00ZPOBI0M/ref=sr_1_1?s=computers&ie=UTF8&qid=1465311947&sr=1-1&keywords=AMD+r9+370+4GB
Good to go! I've got the Strix card and even managed to overclock it a little bit. I just dont want to test my luck, but otherwise, you should be perfectly fine. The MSI card is very good!
Hey,
I'll post my specs below in a minute but I'm just wounder is my
EVGA 500w 80 Plus Power Supply would be fit for my planned upgrade.
I plan on moving to a
MSI AMD R9 380 4GB.
My current specs are
CPU
    AMD FX-4300
GPU
  NVIDIA GeForce GTX 750 Ti
Motherboard
    Gigabyte Technology Co. Ltd. GA-78LMT-USB3 6.0 (Socket M2)
Storage
    931GB Seagate ST1000DM003-1SB10C ATA Device (SATA)
Just looking for some help, I've been looking online for about 2 days and some say it will be fine and others say it won't.
Its gotten kinda confusing and I thought it would help if i made my own post.
Thanks for your time
https://linustechtips.com/topic/607729-just-a-little-help/
1 minute ago, DragonSlayer 159 said:
It will work! I've got a 500w with the same GPU and a Xeon. It's completely fine!
Thanks bro!
https://linustechtips.com/topic/607729-just-a-little-help/#findComment-7867104
Thanks bro!
https://linustechtips.com/topic/607729-just-a-little-help/#findComment-7867113
