Corsair Vs. NZXT
Go to solution Solved by Oshino Shinobu,
1 minute ago, Windows10Home said:
Or should I use all my money going for a Fractal Design Kelvin S36?
I would stick with the X61. A custom loop would be preferable to an S36 IMO.
I am building a budget overclocking build, with the 6600K. I was thinking of overclocking to 4.6 GHz. I narrowed the cooler down, and the ones that were left was: Corsair H80i V2 and NZXT Kraken X61
Which is better?
Windstriker 1.0
CPU: Intel Core i5 6600K
CPU Cooler: NZXT Kraken X61
Motherboard: ASUS Z170-A
Memory: Crucial BallistiX Sport LT DDR4 2400MHz 16gb (2x8GB)
GPU 1: XFX HD 7970 3GB Double Dissipation
GPU 2: Gigabyte HD 7970 3GB Windforce
SSD: HyperX Fury 120GB
HDD: Seagate Barracuda 1TB 7200RPM
Case: Fractal Design Define S
PSU: EVGA SuperNOVA 850 G2
Old Laptop
CPU: Intel Core i3 3110M
IGPU: Intel HD Graphics 4000
Memory: No-Name DDR3 4GB (1x4GB)
HDD: 443GB
https://linustechtips.com/topic/607649-corsair-vs-nzxt/
2 minutes ago, Oshino Shinobu said:
The X61 is better by a landslide.
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/607649-corsair-vs-nzxt/#findComment-7866379
In the page I'm buying from, it doesn't say it supports LGA 1151?! Does it support it??
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/607649-corsair-vs-nzxt/#findComment-7866397
