In the next 2 months I will be conducting my first big build. I will have anywhere between $2000 or $3000 US dollars to spend on a rig that will be for photo editing , video editing , CAD drawings, and also regular everyday use. What I was also hoping to do was to turn the rig into my offsite backup for my NAS at home. I have already chose the monitor and it's going to be 1  LG 34UC87M-B - LED monitor for now. And next year purchase a second. My NAS at home is four 5TB Drives in RAID 5 setup. Any ideas would be greatly appreciated.
https://linustechtips.com/topic/604858-first-big-build-need-ideas/
I left out the GPU as we have two new GPUS being released this month:  The GTX 1070 and the R9/RX 480.
I went with 4xGB stick of RAM as X99 supports quad channel.  If you are sure you will need more than 16GB of RAM:  http://pcpartpicker.com/product/cbtWGX/gskill-memory-f43000c15q32grk
If you are not sure if more than 16GB will be needed, then grab a 2x8GB set for now.  This leaves you the extra two slot to expand in to:  http://pcpartpicker.com/product/MYH48d/corsair-memory-cmk16gx4m2b3000c15
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler  ($56.60 @ Amazon)
Motherboard: Gigabyte GA-X99-UD3P (rev. 1.0) ATX LGA2011-3 Motherboard  ($195.91 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-3000 Memory  ($77.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($149.99 @ NCIX US)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($77.98 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($129.95 @ B&H)
Case Fan: Fractal Design FD-FAN-SSR2-140 66.0 CFM  140mm Fan  ($8.49 @ NCIX US)  <<<Front Intake
Total: $1140.27
Generated by PCPartPicker 2016-06-01 20:34 EDT-0400
PCPartPicker part list: http://pcpartpicker.com/list/4Lxqqk
Price breakdown by merchant: http://pcpartpicker.com/list/4Lxqqk/by_merchant/
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($114.99 @ Amazon)
Motherboard: MSI X99A Raider ATX LGA2011-3 Motherboard  ($199.99 @ Amazon)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory  ($127.99 @ Amazon)
Storage: Hitachi 4TB 3.5" 7200RPM Internal Hard Drive  ($164.00 @ B&H)
Video Card: MSI GeForce GTX 1080 8GB Founders Edition Video Card  ($699.99 @ NCIX US)
Case: NZXT S340 (White) ATX Mid Tower Case  ($61.59 @ NZXT)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Monitor: LG 34UC87M-B 34.0" 60Hz Monitor  ($801.99 @ SuperBiiz)
Total: $2954.51
Generated by PCPartPicker 2016-06-01 20:44 EDT-0400
22 minutes ago, brob said:
Something has to give in that budget. Monitor is > 800. 8TB HDD are > 330. You need a minimum of three (1,000). For realistic backup six or more would be better (2,000).
Like I said I don't need to go with that monitor. I just thought hat I would have more than enough real estate using that monitor. Unless you think doing dual monitors is a better idea. Also as for the offsite backup I could just get away with using it for backing up everything but my media I stream right now. I have never had a reason to do an offsite backup. That is why I'm looking for opinions.
Will this system be used for gaming?
Other than off-site backup, what sort of storage is needed?
I prefer higher resolution monitors over multiples.
Not crazy gaming. Maybe a little here and there. More for video editing and photo editing and CAD designing.
I'll explain the choices:
  • i7-6700K for the higher base clock speed. Perhaps not as good a choice as an i7-5820K for video editing, much better choice for most CAD and photo editing.
  • inexpensive cpu cooler that is relatively quiet and will allow for a reasonable overclock
  • 32GB of memory for better editing performance
  • large ssd for better editing & overall performance
  • GTX 1080 should improve photo & video editing performance, certainly will improve gaming on the high resolution monitor
  • one large hdd, system will handle four more off the motherboard
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($338.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.99 @ NCIX US)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard  ($129.66 @ SuperBiiz)
Memory: Kingston FURY 32GB (2 x 16GB) DDR4-2400 Memory  ($117.99 @ Mac Mall)
Storage: Seagate NAS HDD 8TB 3.5" 5900RPM Internal Hard Drive  ($335.46 @ B&H)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $2751.03
Generated by PCPartPicker 2016-06-02 09:22 EDT-0400
