Hi
I wonder if anyone is able to help me,
I have the Logitech  K350 and I've had it for a few weeks.  It isnt stable at all, when ever i type it rocks from side to side.  It seems as those the top right hand side of the keyboard is not level with the left hand side.  I have to prop it up with folded up paper to support it and make it level with the other side.  It also rocks when i have the tilt legs down too.
Does anyone know what could be the problem?
Thanks
https://linustechtips.com/topic/604823-logitech-k350-issue/
On 6/1/2016 at 11:13 PM, Drunk_Klaus said:
are all the rubber feet still attached?
thanks for the reply.  They are all intact and i have tried it on several different surfaces and its still the same.  It seems as though the right tilt leg is not long enough.
https://linustechtips.com/topic/604823-logitech-k350-issue/#findComment-7842996
