Need help with NAS build
Go to solution Solved by UL_42L,
11 minutes ago, OrrinB said:
Build myself
Well that's gonna be easy. You can use just about any processor I believe, since NAS (Network Attached Storage) doesn't need much power. Any motherboard as well, but you might want to go for something that has plenty of SATA plugs, and of course, make sure it's compatible with whatever processor you choose. Pick any case the stuff fits in, preferably one with a lot of drive bays. It shouldn't need much RAM either, 2-4 GB should do it. Now, you'll want to look online for an operating system/software to put on this for use as a NAS.
Build myself
Thy hath sinneth, and in thy life thou hast fallen to an unholy, unspeakable level of humanity. Thou hast given into your basest needs. And suffered many years under thine Satan-box. However, if thine be willing, as thy hast show yourself to be, thy can ascendeth into thy glorious fold of the glorious church. Go well, my brother, may your temps be low and your frames high. ~ MrDynamicMan
https://linustechtips.com/topic/602739-need-help-with-nas-build/#findComment-7815669
