Ok, so i know that on OSX there is an option for "hot corners" which basically does a certain thing when you move your mouse to the corner. Ever since I moved to PC I fidn it rather difficult and more time consuming to use a computer without this function since windows doesn't have anything like that. So here is my question to all of you, do you know a program that essentially does the same on pc? it must be able to open task view as one of the choices. If not, is there a way to set a shortcut for task view to make my life so much easier?
*edit, I do know that win+tab gives opens task view,
Dell XPS 15 9570 w/ ThinkPad T430
https://linustechtips.com/topic/601837-hot-corners-for-pc/
1 minute ago, GreezyJeezy said:
use keyboard shortcuts ctrl+shift+esc is for task manager
Task view is Windows + Tab
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806256
It would actually be very easy to just write a little program that runs in the background which detects mouse position and then does anything you want when a certain location is detected.  But, knowing the Windows environment, I'm sure someone out there has already done that... many times :)
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806259
alt+tab *
No, Windows + Tab.  Try it.  I said Task View not Task Switcher.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806262
2 minutes ago, Thunder_Ruler0 said:
read again
Here's just one of the many options that probably exist: http://lifehacker.com/5091746/hot-corners-adds-actions-to-desktop-corners
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806273
ive tried this one 10 minutes ago, it doesn't support task view.
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806276
How about this: https://sites.google.com/site/devrexster/dexpose2
http://lifehacker.com/389203/dexpose2-like-mac-expose-but-better
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806281
you view all tasks in alt+tab and windows+tab does nothing for me
Are you using Windows 10?  Because if you're not, that's why.  Task view looks like this:
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/601837-hot-corners-for-pc/#findComment-7806284
