my brothers AMD Athlon(m) x4 860k quad core was running at 100 Celsius. i reinstalled the CPU cooler and the thermal paste is fine, that dropped it to about 80. the CPU fan is running at 100% and here the funny thing. The box the processor came with says its clocked at 3.7ghz, on the task manager it says the max speed is 3.7 yet when i play a game it goes up to 3.8 GHz. I have not overclocked it and i am having a hard time trying to under clock it because when i use AMD overdrive i try to bring the core multiplier (which is at 37x) and bring it down to 27x it freezes the computer. I don't care to much about the performance (because its my brothers and he cant tell the difference) and  I want it to run at a safe 70 degrees or less, my I7 4790k dose not run that hot and we have the same CPU coolers. If y'all can help me over Skype id really appreciate it.
https://linustechtips.com/topic/601708-bros-i-need-overclocking-halp/
If you are going to underclock it you probably have to undervolt it as well.
I've never heard of anyone wanting to underclock. Youre better off buying a new cooler.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
Not super familiar with AMD CPUs, so http://www.tomshardware.com/answers/id-2321266/disable-turbocore-feature-permanently.html.
80 degrees is still safe, but the cooler that comes with the 860K is kind of crap. You can get an aftermarket one.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
