NZXT sells some pretty decent white fans for the price. They are just regular fans, in terms of air flow and sound, nothing like the premium brands out there. That also reflects in the price. Personally i am happy with the FN V2s.
https://www.nzxt.com/categories/fans
MAIN RIG | AMD R7 1800x @ 4.0GHz [cooled by Corsair h110i] | Zotac 1070 founders | Corsair Dominator Platinum 2x8gb |
| ASUS crosshair IV hero | Samsung 960 evo m.2 | Seagate 1TB + WD blue 2TB| Corsair HX750i | Phanteks evlov atx TG |
LAPTOP | HP zbook Workstation | Intel i7-4710 HQ @ 2.5GHz | 8gb ram | NVIDIA Quadro k1100m | 250gb + 250gb Crucial SSDs |
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7772979
Corsair, Phatneks, and Fractal all make good white fans.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7772980
was looking for something completely white.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7772988
Just now, ixiboneheadixi said:
does corsair make fans completely white? and i will look at phanteks and fractal
Completely white as in the fan and frame?
Or just the fan? Or LED?
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7772994
8 minutes ago, ixiboneheadixi said:
yes the fan and the frame in white is what i am looking for.
That I am unsure of. Most common set is a white fan in a black frame.
For white on white, you might have to just get something from AeroCool or BenFenix.
Id settle for one of these low noise Phanteks, though.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709044
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773030
I have quite a bit of time to figure it out anyway, doing a mostly white build in a white caselabs sma8 so i am already having to end up paint a lot of stuff, i did not find a white radiator anywhere and i am probably going to use 3 of them.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773039
1 minute ago, ixiboneheadixi said:
I have quite a bit of time to figure it out anyway, doing a mostly white build in a white caselabs sma8 so i am already having to end up paint a lot of stuff.
Ya, if thats the case i'd just do that which you already are.
Pick up something of good quality and mod it yourself.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773047
I am only in the planning stages right now, but i keep on digging myself a a bigger and more expensive hole with this project LOL.
It is so much easier to go with like a black and red build or something, but i see it so much i decided to go mostly white, with purple and gold accents. 3 colours you cant find dick all of on PC parts.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773061
Someone asked about gold RAM yesterday and the only two I could find where the new yellow G.Skill RAM or a 4x4 Adata kit that was like $200. Of course, I didn't hard search for more options. Good luck on purple, too.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773083
Because I agree, black on red/green/blue is essentially the entire market.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773087
Already decided to go with rigid tubing and probably do a purple coolant as that is easy enough to make. But then stupid me decided that for gold i will just buy a bunch of fittings for the tubing and have them gold plated, not exactly the cheapest move i could make.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773092
The PC i am using right now has bright red ram in it along with red sleeved cables from my EVGA power supply and a gigabyte mobo that has all green everything along with a green LED light strip down it, it looks like christmas in my case.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773099
As bad as this?
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773106
I think the important thing is how amazing it'll look and feel every time you sit down next to it and power it on.
It's like a car. Probably something you use multiple times a day for extended periods of time. It's okay to spend a little extra on something nice.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773107
As bad as this?
Not quite that bad haha.
That and i can momentarily brag about it when i take a picture of the wall of boxes i will have when i order stuff for it. Growing up poor eating out of food banks and shit and then being able to afford all this cool custom PC stuff still really amazes me as stuff like this to me as a kid was just rich people stuff i would never even get to touch. so yeah seeing something ridiculous everytime i sit down to use my PC is not a bad thing lol.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773124
1 hour ago, ixiboneheadixi said:
does anyone sell good white case fans?
Edit: I am looking for completely white, the fan blades and the body of the fan all white.
Silverstone are great.
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/598698-white-case-fans/#findComment-7773233
