Hey guys, so here is my problem.
When I press down the shift or the ctrl key, it remains pressed down.When I type though Presiing shift makes next letter capital but then it resets again.
When I press Ctrl + mouse wheel to zoom on web pages, I have to press it then again, because the scrool wheel keeps zooming in and out even when ctrl is not pressed.
I tried different keyboards and different USB ports and the result is always the same.
I really dont know what to do anymore. I updated all known drivers and even flashed BIOS to the newest version.
Please help if you know what to do.
PC specs:
Mobo: ASUS B85-Pro Gamer
CPU: Intel 4770
GPU: Nvidia GTX 970
https://linustechtips.com/topic/596727-help-shift-and-control-keys-remain-pressed/
1 minute ago, DayHawkCZ said:
I have literally never heard of a sticky key. What is it?
it does what you just described, if im not mistaken
it's meant to allow people to use keyboard with just pressing one key at a time
-sigh- feeling like I'm being too negative lately
Ok, I'll try to find out. Thanks for the tip.
it should be in control panel -> Ease of access -> (under Ease of access centre) Change how your keyboard works
in there you will find the settings
OH MY GOD it worked! You are a savior! Thank you!
you might've enabled it when you press shift for 5 times
you can disable the shortcut in the settings too
i disabled mine because it's annoying :P
Well when it first popped out I did say I donť want this feature. But apparently it turned on somehow.
