Touch the metal on your stove first to grind yourself, can try to handle the mobo by the edges as much as possible. But yeah it's fine.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
13 minutes ago, JGamingToo said:
I just got my mobo in the mail. It is the MSI B85-E45. Is it safe to take it out of the static bag to look at it then put it back in the static bag and the box? or what way should I put the mobo back in the box. Im a newbie at parts and stuff :D
Yeah, just ground youself before you handle it in case you mess it up. Occasionally touch a piece of unfinished/unpainted piece of metal like a radiator.
