Hello I'm currently trying to decide what case to pick for my build. I don't want my price to exceed 1,000$, also don't plan on overclocking my CPU ( any help on a non-overclock motherboard would be helpful too). I really don't want to switch out on my R9 390 for another card.
http://pcpartpicker.com/p/8rTBgs
Thank you,
https://linustechtips.com/topic/592600-first-gaming-pc-build/
Wait a month for the 1080 and 1070?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/592600-first-gaming-pc-build/#findComment-7709629
first off 16GB of ram isnt that much more in price it'd be some padding for the future
2nd you can get 10 Pro off of Kinguin for less than $30.
third you can probably do fine with the i5 6600.
Fourth you can always save more money with Haswell, DDR3 ram is a bit cheaper, but Skylake is fine and now it costs about the same
other than Ram and 10 Home in my opinion it's a really solid budget build plus you can sill save some with the i5 6600
CPU: Intel Core i7 Extreme Edition 3960X | Motherboard: Intel DX79SR "Stormville" | RAM: 32GB G.SKILL Ripjaws Z Series DDR3 PC3-12800 (4x 8GB) Quad-Channel | GPU: 2x EVGA GTX 970 FTW 4GB in SLI (I have Many other builds plus 100+ Macs (don't judge me)... Many specs are listed on my profile)
[PC#1] Log: [Link] [PC#2] Log: [Link] F@H stats: [Link]
https://linustechtips.com/topic/592600-first-gaming-pc-build/#findComment-7709641
Thank you,
That motherboard isn't in stock and hasn't been in stock for a week from Best Buy.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/592600-first-gaming-pc-build/#findComment-7709675
