OK so i've used the Windows Media Creation Tool to make a bootable USB for the PC i'm building. I was wondering if I use this on it if I could use the Windows 10 product key that is already on the PC i'm currently using.
Windows 10 came pre installed on the PC i'm using.
Microsoft help desk says I can't. But can I? Sorry i'm just really confused and worried. This is my first PC build
https://linustechtips.com/topic/592393-boot-help/
Windows keys can only be used once. I think there's a way to deactivate a key to use it again but I doubt it is easy.
You should buy a new key for your new computer.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/592393-boot-help/#findComment-7707477
thats only for retail versions of windows (the $119 ones). prebuilt keys are all tied ot the mobo
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/592393-boot-help/#findComment-7707503
11 minutes ago, MrHazman911 said:
Thank you alot of wait has just been lifted of my back
So into system settings on control panel, System Info, scroll to bottom, copy the Windows Key onto a piece of paper or phone or something, the click de-activate
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/592393-boot-help/#findComment-7707509
Does this actually work? I've seen people deactivate their Windows product key in command prompt but i'm not that sure.
https://linustechtips.com/topic/592393-boot-help/#findComment-7707839
