Alright so I need a 3.5mm audio switch box, with 1 input and 2 outputs, and I want to be able to switch between the 2 outputs with just a press of a button, it'd be a great help if you guys could help me find one, thanks!
https://linustechtips.com/topic/585055-need-help-finding-a-product/
As bad as I hate to sponsor outside resource`s , Of course you could go through THIS SITES LINKS and find it REALLY EASY !! and get a Discount as well but, ..... Amazon , Best Buy , New EGG , etc....... Outside US , ? That is the BEST response I could offer !!! Hope it helps ???
