So im deciding to build a mini ITX build with the node 202 case from fractile design
its gonna have a i7 4790k in it. im not overclocking so that isnt an issue but i want a good low profile cooler that can keep my cpu temps low at stock clocks. i heard in a small case like the node 202, things can get pretty hot. so is there any good cpu coolers ??
https://linustechtips.com/topic/584599-itx-build-cpu-cooler/
For that size case I would recommend the Noctua NH-L9i. There are a few other coolers but they can all have issues with motherboards and ram.
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/584599-itx-build-cpu-cooler/#findComment-7624013
if you opt for the node 202, the coolers you can fit wont allot for much overclocking, be aware of that
unless of course you ghetto mod an AIO in, but only applicable to short GPU (the R9 Nano is pretty much the only card)
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/584599-itx-build-cpu-cooler/#findComment-7624019
i saw this vid, but idk man, i honestly dont want to risk it but if i have to, then ill do this case mod
https://linustechtips.com/topic/584599-itx-build-cpu-cooler/#findComment-7624024
its only applicable for short gpu, and R9 nano is pretty much the only short high end GPU, other than mITX gtx 970, but that performs much slower
what i recommend is getting another case if you wanna overclock
https://linustechtips.com/topic/584599-itx-build-cpu-cooler/#findComment-7624028
would a sp corsair fan be trouble if i replace the fan off the h55 cooler? (for clearance?)
https://linustechtips.com/topic/584599-itx-build-cpu-cooler/#findComment-7624048
