First Computer Build second SLI 980 doing nothing?
Hi,
   I have a 1000w PSU and I have entered all my parts into a PSU calculator and I don't exceed 1000w I sit at around 840 max. Anyways, when I start my computer both my graphics cards light up (Two 980ti's). But when windows loads my second graphics card dims. When I play an SLI enabled game, there is still no load on the second GPU. The GPUs never balance any load. This is my first PC build ever. What am I doing wrong?
ps MSI afterburner sees both graphics cards, but when I scroll over my Nvidia GPU activity monitor it says my second card is inactive.. how do I make it active?
I really appreciate all the help I can get as this is my first build ever and invested a lot into this, I want to get my second graphics card up and active asap for some pwning! Thanks!!!
11 minutes ago, Telebubbies said:
What motherboard do you have? Maybe there is an issue with the PCI?
And also, 2 GTX 980ti's? What games are you planning on playing?
1 GTX 980ti can handle 4k xD
I beg to differ, got SLI 980ti overclocked and still have to turn settings down at 4k (medium to high, modified).
I speak my mind, sorry if thats a problem.
Hi yes SLI bridge is firmly connected. Asus Maximus Hero VIII Republic of Gamers motherboard.
When I play SLI enabled games such as Crysis I don't see any GPU split activity. If I load ten applications all ten show up on the first card.
I checked my motherboard box says "Nvidia SLI ready"
Did you enable SLI in the Nvidia control panel?
LTT Unigine SUPERPOSITION scoreboardhttps://docs.google.com/spreadsheets/d/1jvq_--P35FbqY8Iv_jn3YZ_7iP1I_hR0_vk7DjKsZgI/edit#gid=0
Intel i7 8700k || ASUS Z370-I ITX || AMD Radeon VII || 16GB 4266mhz DDR4 || Silverstone 800W SFX-L || 512GB 950 PRO M.2 + 3.5TB of storage SSD's
SCHIIT Lyr 3 Multibit || HiFiMAN HE-1000 V2 || MrSpeakers Ether C
Ding ding ding
open nvdia control panle go to Sli
click set to max performance under the Sli tab and click apply
it's off by default
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
Thanks for the replies all but still nothing. SLI has been enabled and it is set to max performance. don't know what PhysX but it seems to be using my second GPU.
shouldn't the loads split on SLI enabled games or will I see the load all on one card?
Its very simple to test, find a benchmark and try with SLI enabled and disabled.
If it remains the same, you got a problem, if it does go up with SLI, everything is fine.
1 hour ago, Telebubbies said:
I would have picked a GTX titan X.
980Ti has same performance as Titan X, only difference is VRAM.
You said physx by default took the second card to be the physx card, well the set the physx processor to cpu and then you will be good to go.
Current PC: "For Now Because I Have A Habit"
CPU: Intel Core I7 6700K @4.5Ghz
Motherboard: Asrock Z170 Extreme4
RAM: 16GB G.skill TridentZ 3200Mhz DDR4
CPU Cooler: Thermaltake Water 3.0 360 Riing RGB Edition
Graphics Card: Nvidia Geforce GTX 1080Ti Founders Edition MSI
Case: Limited Edition Thermaltake View 31 Riing RGB
Power Supply: CoolerMaster V750 Fully Modular
SSD: Kingston HyperX Savage 240GB
HDD: 3TB Toshiba 7200RPM
Peripherals:
Monitor: AOC U2868PQU 4K 28" 60HZ
Keyboard: G.Skill Ripjaws KM780 RGB Cherry MX Red
Mouse: Razer Deathadder Elite
Mouse Pad: Razer Goliathus Speed Extended
Speakers: Creative SBS A250
Headphones: Razer Kraken Pro 7.1
