So I have my 4690k overclocked to 4.5 ghz at 1.215v stable. For the cooler I am using a Corsair h110i set as exhause in pull. When I run stress tests the temps are around 65-70c give or take. Today I was doing some gaming (World of Warcraft) and highest cpu temps seemed to be around 55-60c. Do these temps sound right for my setup?
https://linustechtips.com/topic/581526-4690k-overclock-temperature/
2 minutes ago, Bion1985 said:
Cool thanks for the reply, you always hear so many different things about where temps should be it's hard to get a clear answer sometimes.
I mean your stress temps are about 60-70 which is about right. But, you might wanna look and clean them a little bit. 55-60 while playing WoW is quite alarming. I don't remember WoW being that cpu intensive.
Think when I was playing I was at around 40-50% load when st those temps in wow. Also should add that I was in a 5 man dungeon when these temps were  recorded. If I remember riget also I played GTA 5 about a week ago on these oc settings and the temp was somewhere around 65c if I remember correct.
I think it's ok for now since you're way below the danger zone. How long did you have your cooler and when was the last time you cleaned it?
21 minutes ago, YongKang said:
Now that I look at it, it should be fine. If those high temps worry you, turn your oc down a bit and see what kind of temp you're getting. But don't worry too much! :D
Not that I am really worried it's dangerous, more so was looking to see it they fell in the normal range for my system I guess.
