ill try and explain this the best i can...
i recently got a NAS, when i go to Network in windows and click on the NAS its asks for a username and password, i went in as guest to try it out, all works fine. it i open up network agian and click on the NAS no password is required, it just logs right back in. now my issue how do i logout and get it to prompt me for a username and password again so i can login as the admin? so then i can read and write files, and yea i know i can access it through the browser but, want to do it though windows network
thanks
https://linustechtips.com/topic/579017-network-sharing-issue/
thanks
You'll have to go through the Windows Credentials manager.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569072
2 minutes ago, perplex said:
i did that and removed all and still nothing, i didnt restart though, didnt think you should need too
The Credentials manager is how Windows remembers usernames and passwords.
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569081
so how come when i removed what was there, and try to go on the NAS it doesnt ask for username and password again?
do you think i need to restart? i cant yet, transferring files
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569089
2 things, you could have restarted your computer to see for yourself by now.  (Why are people afraid to restart their computer)
Did your computer prompt you to restart?
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569092
ive been transferring files all day, just over hour left. so i cant check yet. and no it didnt ask for a restart, so kinda thought i didnt need to and i was missing something
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569096
So you've had a continuous connection and you expect the computer to just notice the connection is different?
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569329
i expect once i said remove, it should remove it without  a restart, shouldnt be that hard, really. unless it said it needed a restart, anyway i should of just waited that extra hour before posting as i thought the restart fixed it i think, thanks anyway
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569332
Its not the restart that fixed it, it was the fact that you changed the credential while you was accessing the device.  Its like logging out of Amazon right after you click the "Buy Now" button and it is processing your order.  There is no telling what it will do.
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569334
i wasnt accessing the NAS, i was just transferring files on from my pc to external drive, via usb not to the NAS. but yes i can understand if i was accessing the NAS and trying to do that, it would act up, but i wasnt so yea i donno
https://linustechtips.com/topic/579017-network-sharing-issue/#findComment-7569349
